1993 Jeep Cherokee 1993 Jeep Cherokee Windshield Wiper Moto
1993 JEEP CHEROKEE
289,748 MILES • 4 CYL • 2WD • MANUAL
SUPER_BRE
How do you replace the windshield wiper motor? Or how do I know that's what's wrong with it.
When you turn the wipers on it acts like it wants to run (you can hear the whirring noise) but the wipers aren't budging.
Any help is greatly appreciated!
Oct 16, 2008 at 9:29 AM
JNOVACK
  • 723 POSTS
Removal & Installation Front See Figures 1, 2, 3, 4, 5, 6, 7 and 8 Fig. 1: Remove the wiper arms Fig. 2: Remove the cowl panel retaining screws Fig. 3: Remove the cowl panel Fig. 4: Disengage the wiper motor electrical connectionFig. 5: Unfasten the wiper motor retainers Fig. 6: Remove the wiper motor and linkage Fig. 7: Unfasten the wiper motor-to-linkage retaining fasteners Fig. 8: Separate the motor from the wiper arm Remove the wiper arm and blade assemblies. Remove the cowl trim panel. Disconnect the washer hose. Remove the cowl mounting bracket attaching nuts and pivot pin attaching screws. Disconnect the wiring harness and unfasten the wiper motor retainers. Remove the wiper motor and the plastic motor cover, if equipped. Remove the retainers holding the motor to the linkage assembly and bracket. To install: Install the retainers holding the motor to the linkage assembly and bracket. Install the wiper motor and the plastic motor cover if equipped. Engage the wiring harness and fasten the wiper motor retainers. Tighten the mounting nuts to 35 inch lbs. (4 Nm). Install the cowl mounting bracket attaching nuts and pivot pin attaching screws. Engage the washer hose, install the cowl trim panel and the wiper arm and blade assemblies
https://www.2carpros.com/forum/automotive_pictures/52960_0900c152800a9d4c_1.jpg
https://www.2carpros.com/forum/automotive_pictures/52960_0900c152800a9d4d_1.jpg
https://www.2carpros.com/forum/automotive_pictures/52960_0900c152800a9d4e_1.jpg
https://www.2carpros.com/forum/automotive_pictures/52960_0900c152800a9d4f_1.jpg
https://www.2carpros.com/forum/automotive_pictures/52960_0900c152800a9d50_1.jpg
https://www.2carpros.com/forum/automotive_pictures/52960_0900c152800a9d51_1.jpg
https://www.2carpros.com/forum/automotive_pictures/52960_0900c152800a9d52_1.jpg
https://www.2carpros.com/forum/automotive_pictures/52960_0900c152800a9d53_1.jpg
Oct 16, 2008 at 10:36 AM
SUPER_BRE
Thank you SOOOOOOOO Much!!!!
Oct 16, 2008 at 10:56 AM
JNOVACK
  • 723 POSTS
any time thank you
Oct 16, 2008 at 11:27 AM
