[quote:acc5a3302d="Jacobandnickolas"]Is that voltage in or out? Also, make sure the wires are not corroded or internally damaged. Follow the wire to its source to determine if the wire or the source is the problem.[/quote:acc5a3302d] The voltage stays the same going in and going out of the resistor. I cut into the wire leading out of the fuse box that leads to the resistor and out of there it read the same about 1.80 or close. I decided I'd check different circuit so i tested the map sensor It also had only bout 1.80 volts and that is a completely different circuit than the fuel. I pulled the new auto shutdown relay out and tried to replace it with another and I was back to nothing. So I put the relay I had pulled out back in and now dont have anything at all again going to the resistor. The wires leading into the fuse box has full 12.50 volts around there. And I lost my spark again.
Apr 8, 2009 at 10:34 AM
