1.I have to replace my ignition key lock cyl. I have the steering wheel off,lower tim panel off. I am having trouble getting the steering column shrouds off. Where are the retaining screws?
2.Do I need to disconnect the ignition switch rod?
3.Is this model have the thru bolt style key cyl. or is it retained by a clip; if so, is there a special tool?
4.Also,the key does not turn the ignition anymore.Will this be a problem in the installation or removal of the ignition lock cyl?
Jan 16, 2009 at 5:43 PM
