1990 Jeep Cherokee Gas in Oil
1990 JEEP CHEROKEE
147,000 MILES • 6 CYL • 4WD • AUTOMATIC
TENA
the oil is consistantly saturated (very thin) with gasoline. I have had the fuel regulator changed, injectors adjusted. I had an oil change 2/20/08 and it is very saturated with gas already. Now the motor is knocking very loudly.
Can you please help
Mar 19, 2008 at 7:12 PM
BLACKOP555
  • 10,386 POSTS
perform a compression and cylinder leak down test on the cyolinders you may have worn piston rings.
Mar 19, 2008 at 9:05 PM
D5NUKE
  • 61 POSTS
This is caused when there is a problem, such as a stuck fuel injector, an inoperative ignition system, or a fuel flooded engine, where the cylinders are overwhelmed by fuel, and the piston rings become unseated from the cylinder walls, and there is a breech that allows larger amounts of fuel past, into the oil below. If this happens, once the problem is repaired, the oil needs to be changed.
Small amounts of gas in oil is ok. But allot can cause the oil to be to thin and not lubricate well enough. IF the piston rings are worn the gas can get into the oil.
Mar 19, 2008 at 9:13 PM
