1989 Jeep Cherokee belt
1989 JEEP CHEROKEE
218,000 MILES • 6 CYL • 4WD • MANUAL
TRINA&LOGAN
my belt wont stop squealing, we replaced the water pump, nothing happened, we put a new $50 belt on and its still making so much noise.it has to be the belt because when we put water or sometihing on the belt it stops making noise for a minute but then starts again. what should i do next?
May 13, 2009 at 1:56 PM
Is the belt tight enough? Also, make sure the pulleys are not glazed. If they are, you will need to try to clean them with a strong cleaner (degreaser) to see if that helps. If you replace the belt, chances are it needs to be a little tighter and double check the routing to make sure it is correctly installed.
May 17, 2009 at 3:15 PM
