1989 Jeep Cherokee Battery meter goes down when put in gear
1989 JEEP CHEROKEE
CAR_DAD
Electrical problem
1989 Jeep Cherokee 4 cyl Four Wheel Drive Manual
Having a problem with my electrical system. When the jeep idles, the meter seems to be fine, where it should be. When I put the jeep into gear and start to go, the meter goes as if the battery has no life and the lights dim, the radio goes out, blinkers slow down. Thoought it was the altenator, had it rebuild (by a reputable shop) but has mad no difference.
Any ideas what to check next.
Mar 26, 2010 at 5:12 AM
BMRFIXIT
  • 19,053 POSTS
1st have to check the charging volts and charging
system
check for codes
check fuses and wiring harness to and from the alternator
Mar 26, 2010 at 5:51 AM
