I have recently had a CA emissions test and the engine passed w/no problem, but the guy said it 'poured raw fuel' out from the rear (by the tank) when he 'pressurized the system'. He would not tell me which fitting or hose was leaking. I could not see any leak, but I had the fuel llines from the tank to the steel lines replaced along with the in-line fuel filter and returned for the re-check. Failed again. He says it's just pouring out with a 1/2 lb. pressure, but I have run the can at idle and around the block for 30 minutes and there is no leaking that I can seel, nor is there any gas on the frame or the underside of the tank. Does the tank need this 'pressurization' in order to see such a 'pouring' leak? If so, how can I pressurize it? Thank you.
Jun 23, 2009 at 4:48 PM
