1986 Jeep Cherokee clutch hydraulic system
1986 JEEP CHEROKEE
230,000 MILES • 4 CYL • 4WD • MANUAL
ARRUSSO
  • 4 POSTS
We have owned this jeep for 16 years. We have replaced the clutch master cylinder many times. The pedal will go to the floor and you have to pump it to get the pedal back. The fluiid will get very dirty. We just replaced the slave, master and line between master and slave. 5 monthas later it is doing it agian and fluid is also dirty again. I saw on the internet that many people have had this problem with different years. Does anybody have a solution to this?
Dec 31, 2007 at 11:57 AM
2CARPRO JACK
  • 11,533 POSTS
When it is working properly, does the pedal feel hard to push? Cant think of a single reason that would happen other than an aftermarket clutch that is too stiff for the hydraulics.
Jan 3, 2008 at 7:36 AM
ARRUSSO
  • 4 POSTS
[quote:3e71db18a9="2CarPro Jack"]When it is working properly, does the pedal feel hard to push? Cant think of a single reason that would happen other than an aftermarket clutch that is too stiff for the hydraulics.[/quote:3e71db18a9]
No the clutch is not stiff. This has neen an on going problem for years.
Jan 3, 2008 at 8:34 PM
2CARPRO JACK
  • 11,533 POSTS
I personally have never heard of it being an ongoing problem. What brand parts did yo use when it was all replaced? When the pedal goes soft... does it leak any fluid out?
Jan 4, 2008 at 7:22 AM
ARRUSSO
  • 4 POSTS
[quote:e9deb7d103="2CarPro Jack"]I personally have never heard of it being an ongoing problem. What brand parts did yo use when it was all replaced? When the pedal goes soft... does it leak any fluid out?[/quote:e9deb7d103]
The master cylinder does leak fluid where the push rod goes. I think the last replacedment was a Wagner. The parts company has just warrantied the master for the second time. The previous replacement was in April. I noticed that the previous two cylinders were cast iron and the one I just got is an aluminum one made in Taiwan. I do remember that the original was an aluminum made by Lucas.
----Thanks for your help.
Jan 4, 2008 at 8:39 PM
2CARPRO JACK
  • 11,533 POSTS
That many problems, you might want try an OEM part.........
Jan 5, 2008 at 8:04 AM
ARRUSSO
  • 4 POSTS
1986 Jeep Cherokee[quote:8760928a46="arrusso"][quote:8760928a46="2CarPro Jack"]I personally have never heard of it being an ongoing problem. What brand parts did yo use when it was all replaced? When the pedal goes soft... does it leak any fluid out?[/quote:8760928a46]
----Thanks for your help.[/quote:8760928a46]
Thank you, we will try that next time.
Jan 5, 2008 at 11:11 AM
2CARPRO JACK
  • 11,533 POSTS
Strange problem, hope that fixes it
Jan 6, 2008 at 7:25 AM
