Transmission problem
1985 Jeep Cherokee 6 cyl Four Wheel Drive Manual 146k miles
I recently replaced both master and slave cilynders. After I replaced the slave cilynder it stopped holding pressure, no matter how many times I bleed/purge it. I was wondering if the line with the rubber section was used to build pressure i should replace that to. there is some pressure all the way at the bottom of the pedal but not nearly enough. Any help would be great thanks!
Sep 2, 2008 at 4:24 PM
