the above vehicle's convertible was working fine until jsut yesterday. i opened the roof and now i can't close it or the rear 1/4 windows.... the key in the door will also not close the roof either. i checked the fuse box in the trunk and noted the 40 amp raise-lower pump fuse was blown. i replaced it and it keeps blowing out whenever i try to close the convertible top with the key or switch on the console. is this a relay problem, a hydraulic problem, a pump problem or an electrical short somewhere else in the vehicle???? Thanks in advance for your response. BTW: Do i need to take this to a certified Jag dealer for the repair, cha-ching or can a reputable car mechanic help with this problem?
Mar 29, 2010 at 11:14 PM
