Hello -
RADIATOR LOWER HOSE
Removal
1. Open the engine compartment and fit paintwork protection sheets.
2. Drain the radiator. Retain the coolant drain tray in position to catch any spillage when removing the thermostat cover.
3. Disconnect the radiator bottom hose from the thermostat cover.
1. Release and reposition the hose clip, and disconnect the bottom hose.
Fig. 83: Disconnecting Radiator Bottom Hose From Thermostat Cover
Courtesy of JAGUAR CARS, INC.
4. Disconnect the bottom hose from the radiator.
1. Slacken the hose retaining clip and reposition the clip along the hose.
2. Disconnect the hose from the radiator.
Fig. 84: Disconnecting Bottom Hose From Radiator
5. Remove the spring band clips from the hose.
Installation
1. Installation is the reverse of the removal procedure.
2. Refill the cooling system
Dec 26, 2009 at 5:43 PM
