Had engine replaced with all the updates about 4 years ago 40000 miles. At 80,000(same time) the trans fluid was also replaced and tranny was check out. Notice some spots on driveway probably from transmission. Can not check the level. The rattleing could even be from engine but it happens when trans shifts. Sounds like the engine is out of time. Jag dealer said there were no engine codes. Does the codes also include the tranny? I now have an engine lite on since yesterday. I put some sea foam gas cleaner and the engine now idles smooth but lite is still on?
Also the heater no longer blows heat just cooling?
Oct 9, 2010 at 12:29 PM
