2000 S-type coolant level sensor elimination
2000 JAGUAR XJS
GARYGABLE
The coolant expansion tank on my 2000 S-Type was replaced, but the replacement tank has no place for the coolant level sensor. A Jaguar service bulletin shows that the sensor has been "eliminated" so now this is the only type of tank available. But with the sensor disconnected (or even connected and not in liquid) a low coolant level warning message appears. How can I actually eliminate the sensor, which is an optical sensor, in such a way as to eliminate the message?
Jan 25, 2006 at 11:17 AM
2CARPRO JACK
  • 11,533 POSTS
try capping the optical end of it
Jan 31, 2006 at 5:45 PM
FSTRANGER302
  • 117 POSTS
you need to cut the wiring for the low levell sensor. and tape off. also you need to have ecm reprogramedd to shut off the low levell sensor.
Sep 20, 2006 at 8:57 PM
