2000 Jaguar S-Type changing rear brakes
2000 JAGUAR XJS
GMELENYZER
I’m preparing to change the rear brake pads. I’ve had problem in the past compressing the caliper on other models. Some have to be turned to compress due to the parking brake feature. Is there a “trick” I need to know on this car to get the brake caliper to compress to install the new brake pad?
Jan 7, 2007 at 9:59 AM
BRUCE HUNT
  • 3,754 POSTS
Are you getting a check engine light on the car. I would check for code in the computer. Sounds like a sensor or a relay.
Oct 18, 2006 at 3:23 PM
BESTBET777
  • 89 POSTS
Get a caliper compression tool.
Apr 20, 2007 at 7:53 PM
TRASHDI
Sometimes you compress claier by opening the bleed screw ...when you compress calipers the fluid bleeds out. Make sure you replace the brake fluid you lost during compression by using a propoer bleed kit ( $10) ...So you get to compress calipers easily and change brake fluid at the same time..!!!
May 16, 2007 at 4:06 PM
