1995 Jaguar XJS Knocking when driving over bumbs
1995 JAGUAR XJS
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
PHILIPNY
My XJS has been making a knocking sound that has gotten worse, I check under the hood and discovered that the rubber bearings on both sides above the wheel have rotted.When I removed a wheel, I saw that there is more rubber that has deteriorated. Is this something I can fix myself? what parts would I need? Should I replace more than just the rubber?
Sep 5, 2008 at 11:02 PM
HIGGINS11
  • 5 POSTS
you can do this on your own. you can get the new bushings from your local jag dealer. it might not be a bad idea to do the shocks while you are in there.
Mar 31, 2009 at 2:19 PM
