Hello –
Hey I have a good idea………….why not this time I put the info with this…………
HEATER CORE
Removal & Installation
1. Disconnect negative battery cable. Drain engine cooling system. Remove left hand console side casing and dash liner. Remove glove box. Remove heater box cover screws. Remove rear heater box panel and move front panel and foam seal out of the way for access.
2. Disconnect heater pipe from heater box. Remove and discard gasket. Disconnect wire from coolant temperature switch. Remove foam pad from pipes and move vacuum hoses out of the way. Remove front heater panel. Disconnect heater hoses from heater core and remove heater core. To install, reverse removal procedure. Ensure new gaskets are used.
Aug 19, 2009 at 9:58 PM
