1991 Jaguar XJS Rear Power windows inoperative
1991 JAGUAR XJS
CSFIVESTAR
Electrical problem
1991 Jaguar XJS Engine Size unknown Two Wheel Drive Automatic 20000 miles
The front power windows were working intermitantly, which was caused by faulty window switches. I replaced them and the front is fine. The rear windows which are activated when the convertable top is opened or raised. They are both stuck in the open position. The top works well but does not close the windows. There is supposed to be an 8 second delay so it is necessary to hold the switch for several seconds, which i have done.
I checked the fuses but don't know where to go from here. It is impossible to get to the motors to check for power.
Any help would be much appreciated.
Thank you,
Chris
Jan 9, 2008 at 5:27 PM
FSTRANGER302
  • 117 POSTS
[quote="csfivestar"]Electrical problem
Thank you,
Chris
hello, try lowering the top all the way and then raise it up the windows should go up when the top is just about all the way up. if they do not. you either got a relay problem which the relays are inside trunk behind the front seats. right side. under a cover or bad motors. let me know how it goes after you try this... pat
Jan 19, 2008 at 1:52 PM
