1991 Jaguar XJS ABS Accumulator
1991 JAGUAR XJS
48,000 MILES • V12 • 2WD • AUTOMATIC
ITSALLGOOD
  • 37 POSTS
Everytime I step on the brake pedal, the ABS pump will come on, if I keep holding the brake pedal, after about 5 seconds the brake light will come on, then after another 4 seconds the ABS light will come on also. After I remove my foot from the pedal, the pump wil keep running, and about 6 seconds later - the ABS light will turn off (pump still running), then about 5 seconds later the Brake light will turn off (pump still running), then about 6 seconds later the pump sounds like it is working against pressure and it will stop running. Everything is happy untill I get to the next stop sign, then the whole story starts over again. If I need to wait at a stop light (holding the brake) - the pump just keeps running (I don't think thats good for the pump).
I'm pretty sure that I need to replace the accumulator......looks easy enough, just unscrew the old one and screw the new one in?
There is a BIG warning on top of the old one, "Do Not Remove. High Pressure Brake Fluid"
Well, I'm pretty sure that if I pump the brake a few times - there isn't much pressure left in there. Anybody replaced one before?
Jun 16, 2008 at 7:44 PM
2CARPRO JACK
  • 11,533 POSTS
You need to pump the pedal at least 20 times, then the brake pedal will get hard and it should be all good at that point
Jun 19, 2008 at 7:45 AM
ITSALLGOOD
  • 37 POSTS
Thanks for the information!
If I replace the pump and accumuator, I'm pretty sure that I'll need to bleed the system, is there a special procedure for that? - or will I need to just bleed each wheel - same as any other car?
Jun 19, 2008 at 9:36 PM
2CARPRO JACK
  • 11,533 POSTS
According to my software there is no special procedure, start right rear, left rear, right front , left front
Jun 20, 2008 at 7:32 AM
ITSALLGOOD
  • 37 POSTS
...This car does NOT have brakes on the rear wheels!
Just 2 monster calipers on the front wheels. Bleeding the lines seemed easy enough. Not sure exactly if the accunulator is bad or the valve block? If someone holds the brake pedal I can hear the brake fluid flowing throught the valve block for about 7 or 8 seconds before the pedal goes hard. Is there anyway for the valve block to be open so that the brake fluid can flow through it so easily? Or - is the problem just that the accumulator is weak? I'm thinking more that the valve block is bad - because I do NOT need to pump the pedal to releive the pressure from the accumuator. All I need to do is hold the pedal for about 10 seconds, and all the pressure will be gone.
Jun 23, 2008 at 3:45 AM
2CARPRO JACK
  • 11,533 POSTS
The rear brakes are "inboard" on that car, they are next to the center of the diff.
I suggest you go here
https://www.2carpros.com/diagrams
In there you will find the complete diagnostic chart for your ABS problem, you can look it up by symptom
Jun 23, 2008 at 7:21 AM
