1990 Jaguar XJS backfiring left side after warm up
1990 JAGUAR XJS
93,000 MILES • V12 • 2WD • AUTOMATIC
RATMAN117
MEMBER
1 POST
FOLLOW
when engine is cold it starts ok runs ok until warm up it starts back firing on left side of the dual exhaust and runs bad.
Jun 28, 2008 at 12:31 AM
SHADOWFOX1986
MEMBER
I assume it is a v-12 with Marelli ignition. Check your distributor cap and and rotor. Remove the rotor to see if it has been short circuiting to the rotor base, the metal part that spins the rotor. I had a similar problem on the passenger/right bank a few months ago. my rotor was short circuiting, also engine oil was spraying into the distributor because of a bad seal and pcv system. Hope this helps.
