I have wind noise in the drivers door around the window seal but it doesnt appear to be the seal. The reason is, if I grab the door frame up at the top left hand corner and pull it in while I am driving I can get the wind noise to stop. the door doesnt feel loose, no play in it at all, but I can still pull it in ever so slightly and the noise is gone. Is there a way to make a drivers door adjustment so the door shuts more tightly? Again, the door is not loose but if you pull on it even an 1/8" or so it does stop the noise. I saw the post on a 2001 xj with a similar problem but they were told to replace the seal. I tried putting an additional rubber seal in the door last night and closing the door and I still had the noise. can someone shed some light?
rj
rj
Dec 7, 2006 at 4:47 PM
