Jaguar xj8 oil change
JAGUAR XJ8
KOOLWHITECAT
I have a 2004 XJ8. i need to remove the cover panel beneath the car to get to the oil pan and filer. i remove most of the screws and able to see the filer and oil pan. however, there 3 screws (a round 1inch in diameter with a tiny hole in the middle) left i cann't figure out how to remove them.
please help.
thanks
Apr 13, 2006 at 1:26 PM
2CARPRO JACK
  • 11,533 POSTS
try prying them up, they might be push buttons
Apr 25, 2006 at 4:50 PM
FSTRANGER302
  • 117 POSTS
there are two nuts in the center, some have three bolts in the front and 4 in the back. also it has two screws inside two holes in the front remove all the above and the cover will falldown
Sep 20, 2006 at 9:03 PM
KOOLWHITECAT
That was it! thank you "fstranger302".
[quote:9e50e827e1="fstranger302"]there are two nuts in the center, some have three bolts in the front and 4 in the back. also it has two screws inside two holes in the front remove all the above and the cover will falldown[/quote:9e50e827e1]
Sep 21, 2006 at 10:48 AM
