2000 Jaguar XJ8 Rear Differential
2000 JAGUAR XJ8
180,000 MILES • V8 • 2WD • AUTOMATIC
VIKINGSIMON
My differential is making noise, i read it is possibly out of oil.
Is there an easy way to replace the oil or do we have to remove half of the back end to do so :) ?[img:22b13928e5]http://www.2carpros.com/forum/automotive_pictures/415392_IMG_0126_1.jpg[/img:22b13928e5]
Sep 29, 2009 at 1:19 PM
DAVE H
  • 13,384 POSTS
XJR, XJ8, XKR & XK8
The 14 HU differential assembly that is used is a hypoid unit with pinion arranged on the cross-car centerline. Drive shaft connection uses a cassette type pinion oil seal, which is an integral part of the pinion flange. Seal cannot be separated from the pinion flange and must be replaced as a complete seal/flange assembly. The axle shafts are driven by the output flanges which rotate on sealed bearings, these assemblies are retained in differential unit by circlips. The differential assembly is filled for life using a thermally stable lubricant. Serviceable differential components include the pinion flange/seal assembly, pinion flange nut, output shaft bearing "O" ring, output shaft bearing circlip, output shaft bearing and output shaft.
Dec 31, 2009 at 9:39 PM
