i had the primary timing chains and all tensioners replaced, after mechanic finished, the engine has a very bad miss at low idle.
Aug 3, 2010 at 2:46 PM
JAGTECH360
MEMBER
You have a few possibilities. Either it is not timed correctly or you have bent valves. Depending on who installed the tensioners and his/her knowledge and access to the special tools required, this could easily get messed up. If the tensioner failed whilst you were driving, it could have damaged a valve.
