1998 Jaguar xj8 oil change
1998 JAGUAR XJ8
THUNDERCAT
:roll: I am trying to change the oil in my 1998 Jag but I can't seem to remove the oil drain plug. Also it is making a horrible clicking noise when I first start it, then it goes away after a few minutes. What could this be? Thank you.
Apr 22, 2006 at 9:15 PM
2CARPRO JACK
  • 11,533 POSTS
sounds like it slow to oil the engine. Be sure to use the manufacturer recommended oil weight
Apr 25, 2006 at 4:45 PM
FSTRANGER302
  • 117 POSTS
the noise may be the secondary tensioners the plastic will break off. need to go to dealer or qualified notice i said qualified mechanic to do if not done right will possibly cause engine damage. the drain plug should just come off unless it was cross threaded
Sep 20, 2006 at 9:24 PM
