I got a 95 XJ6 which is started to play with me a few weeks ago. If I do not use the A/C, the engine shuts off when I start to accelerate. Not every time does it,but very offen. Therefore I thougt this could be the TPS. I already change that,same thing. When the A/C is on, then it shuts off at idle before I would give some gas. Does this car have overload protection relay? Till yestarday, I didn't have any codes. Now I have the P0727. I changed the crank sensor,fuel pump relay,spurk plags,ignition realy under the hood,(at the fuse box on the right side) and the car still does it when I drive it. But if I just leave it running without A/C and the transmission is in P position,never shuts off. Meaning,when the engine is not loaded. Can you please help me what could be the problem with this car?
Jul 24, 2007 at 7:24 PM
