idle problem
JAGUAR XJ6
$MONEYMAN
i have a 1990 jaguar xj6 and the idle jumps often it also idles very very low and is very rough
Jan 19, 2006 at 3:01 PM
First check for vacuum leaks, if ok, scan main pcm with our pocket scanner, repair trouble codes to recheck system. If no codes are present then try replacing the idle air control motor. :D
Jan 23, 2006 at 6:37 PM
HEAVNZ_WARRIOR
  • 8 POSTS
^^^^ :D
Jan 26, 2006 at 5:03 AM
