93 xj6 transmission shifting hard
1993 JAGUAR XJ6
JDDUNBAR
1.engine light comes on intermitently, transmission shifts hard, is my problem a sensor? if so where is sensor located for me to repair?
when light is not on transmission shifts correctly.
93 jaguar xj6, 125000
2. driver rear door will not open. how can i get it open to chk for latch problems
Sep 11, 2007 at 10:34 PM
SWVE
I have a 1999 XJR with the same problem. I was able to open the door from the inside which bought me a few month's time (the handle worked for period of time from the outside thereafter). As of last week this trick didn't work anymore. I was informed by my mechanic that I need to buy a new handle. He also mentioned that it is not common, but sometimes the rod within the door becomes disengaged---you would need to open up the door panel and reattach it...you may want to check prior to purchasing a new handle.
If it's any consolation, I was informed that this is a common problem.
SWVE
Fellow Jaguar Owner
Dec 25, 2007 at 2:59 PM
