Heater problem
1995 Jaguar XJ6 Engine Size unknown Two Wheel Drive Automatic 140000 miles
I can only get cold air through my heater even when set to max. Local jag dealer said common problem was the heater water pump. I replaced at considerable expense but still no warm air using a length of pipe i can hear water running trough this pump and the water heater valve so presume the matrix is clear. temp of car on the gauge is normal any suggestions would be appreciated
Dec 17, 2007 at 5:04 AM
