1995 Jaguar XJ6 CAR WILL NOT START
1995 JAGUAR XJ6
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
MILLER1
WHEN YOU TURN THE KEY THE STARTER SOUNDS LIKE IT IS WORKING AND ALL THE ELECTRICAL SYSTEMS SEEM TO BE WORKING BUT THE CAR WILL NOT START
Jun 7, 2010 at 11:06 AM
Lets do below for a start to determine if its fuel or spark related issue and get back asap.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 8, 2010 at 9:02 PM
