1994 Jaguar XJ6 Electric seats and windows
1994 JAGUAR XJ6
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
WIRTHANS
I can not get my driver's side electric seat adjustments to work. The fuses are fine, and the passenger side switches work for the passenger side seat. Also ...I can not get the individual windows to roll down, but they will work from the driver's door, and the window lock swith is off. Do you have any suggestions on how to fix these electrical problems?
Jan 7, 2009 at 4:11 PM
JAMES W.
  • 2,394 POSTS
Drivers seat; If fuses #3, 4, 9 & 12 are good in the rt side fuse panel then I would say your control module is bad. Module is located under the drivers seat.
Windows; If you can only open and close the windows from the driver's panel, I would say the lockout switch on the driver's control is still engaged even though it may show "off".
Jan 9, 2009 at 9:52 PM
