1993 Jaguar XJ6 engine top end re-built year ago, oil still
1993 JAGUAR XJ6
125,000 MILES • V8 • 2WD • AUTOMATIC
PURFECT
oil going from crnkcase to airintake via hose from filler tube on valve cover...Also alot of condisation build up (foaming tan oil) at filler tube. Dont drive car much , maybe 40 miles per week.
Nov 29, 2008 at 6:58 PM
KHLOW2008
  • 41,814 POSTS
Hi purfect,
Thank you for the donation.
Foaming of tan oil is a sign of water in oil. You might have a blown cylinder head gasket or bad head. This would cause excessive blowby gases resulting in the oil getting to the intake hose.
You should have shortage of coolant in the radiator and if driven over long distance the engine should be overheating.
You need to get it repaired asap to avoid additional damages to the engine.
Dec 2, 2008 at 9:53 AM
