First check to see if you have 12 volts coming to, and passing through the window switch going to the window motor. If you have 12 volts at the motor, the motor is bad and will have to be replaced. Sometimes a good hard rap on the motor will get them working again. Hope this helps.
Dec 2, 2008 at 7:48 PM
