1992 Jaguar XJ6 Power steering pump
1992 JAGUAR XJ6
13,000 MILES • 6 CYL • 2WD • AUTOMATIC
GELVISP
I have a leaking power steering pump, it looks as if the seal has gone on the front, the pump still works fine. will I have to replace the whole pump or will replacing the seal be adequate?
Feb 10, 2008 at 10:40 AM
JAMES W.
  • 2,394 POSTS
Usually if the seal is leaking the shaft is also worn and a new seal probably won't last very long. You will be money ahead to replace the pump.
Oct 8, 2008 at 9:20 AM
