1991 Jaguar XJ6 Boot lock will not turn
1991 JAGUAR XJ6
61,000 MILES • 6 CYL • 2WD • AUTOMATIC
JUSTINHORNE
When i put the key in the barrel i t does not turn the boot opens and closes no problem but i cant lock it. Do i need a new barrel or is this a common problem?
Also my aerial doesn't come down when i switch the radio off - it has a new wharfdale cd player which was in there when i bought it - could it be the way this was in stalled?
Jan 21, 2009 at 7:53 AM
JAMES W.
  • 2,394 POSTS
Check the linkage rod from the key barrel to the latch. It's probably loose or missing.
Your antenna is probably not connected correctly to the aftermarket radio.
Mar 31, 2009 at 12:55 AM
