1989 Jaguar XJ6 no power
1989 JAGUAR XJ6
202,189 MILES • 6 CYL • 2WD • AUTOMATIC
BERKEBILEMIKE
I changed the fuel pump, fuel filter, and fuel presure regulator. But the car when you go to give it gas it falls on it's face. Plus the check engine light is coming on.
Dec 12, 2009 at 3:58 PM
DAVE H
  • 13,384 POSTS
RETRIEVING CODES
When a system fault has been detected, trouble codes can be retrieved. Vehicle must be stationary. With ignition switch in OFF position, wait 5 seconds and then turn ignition switch to position II. DO NOT start engine. Press Vehicle Condition Monitor (VCM) button, located on VCM/trip computer display panel.
Applicable trouble code will be displayed on display panel. See appropriate code in TROUBLE CODE IDENTIFICATION table for probable cause. When engine is started, trouble code will be deleted from written display, but the CHECK ENGINE light will remain on.
Dec 31, 2009 at 7:59 AM
