Engine will only start with starting fluid. Has fire to plugs and fuel to fuel rail and out of fuel regulator with pressure. New coil, crank relay, plugs, ignition amp. Cleaned MAF. After starting with starting fluid engine runs perfect, on hwy hits 120 in seconds and is smooth as silk at idle, but after turning off, will not start back up without starting fluid. Can not afford to take car to Jag shop at 70.00 hr. but would pay for the correct answer before I pull my hair out! [email protected] or 615-870-3073
Feb 24, 2010 at 4:52 PM
