My 1987 Jaguar xj6 shut down while driving. I checked and was not getting any gas. I replace the fuel pump,which had a very faint hum when running. After replaceing the pump the car will not start,I check for voltage at the pump and did'nt have any voltage. I check for voltage at the relay had voltage at one of the 5 pins but no output voltage to the pump. I replace the relay and still no voltage to the pump. I checked the wire from the fuel pump to the relay and found no shorts. These test were done while cranking and ignition on. I went as far as to disconect the (-) negitave cable from the battery and clip a test light to the terminal and the probe to the (-) post of the battery to check for shorts, and found no shorts. Whats up.
Nov 11, 2008 at 10:58 PM
