1986 Jaguar XJ6 Fuel Injectors
1986 JAGUAR XJ6
45,000 MILES • 6 CYL • 2WD • AUTOMATIC
MREDMOND280
I have a 1986 Jaguar XJ6 that will not start. It cranks good and has spark at the plugs and the fuel system is delivering fuel up to the injectors. I believe the injectors are not working and I don't know how to verify what is not working. Can you help me?
Jun 24, 2008 at 10:17 AM
JAMES W.
  • 2,394 POSTS
testing injector inputs. You will need a special tool to check injector pulse voltage called a "noid light" which is installed into the injector connector harness. They can be purchased at any good auto parts store. Crank or start the engine. light should blink with each injector pulse. I your case you may want to check 2 or 3. If no pulse, the injector control comes directly from the ECU. You may want to change this out with either a used or rebuilt unit. Good luck.
Sep 28, 2008 at 7:02 PM
