1985 Jaguar XJ6 Engine Idle
1985 JAGUAR XJ6
151,000 MILES • 6 CYL • 2WD • AUTOMATIC
PAULIE4859
My jaguar idles too high, how can i turn the idle down?
Jan 27, 2010 at 9:31 PM
DAVE H
  • 13,384 POSTS
IDLE SPEED
The following adjustments must be performed with engine at normal operating temperature, air filter in good condition and ignition timing and valve clearance adjusted to specifications. Check that throttle linkage is operating properly, and that return springs are secure and operating.
Start engine and run for 2-3 minutes. Turn idle speed adjusting screw to obtain proper specification. Idle speed screw is located on air distribution block on XJ6.
Feb 7, 2010 at 7:17 PM
