My vehicle steering is loose from riht to left.The steering column is not loose.Just much play in wheel to turn.Thanks!
Dec 16, 2008 at 1:36 PM
MHPAUTOS
CERTIFIED EXPERT
Hi there,
you will need to check the steering rack for worn attach points, also the attach clamp for the steering column to the rack pinion, check for leaks and worn tie rod ends, start here.
