The car misses after it reaches operating temperature at all rpms more noticeable at an idle
May 23, 2009 at 1:24 PM
CERTIFIED EXPERT
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
