Camshaft Position (CMP) Sensor LH (18.31.12)
Removal
Vehicles with 3.5L or 4.2L engine without supercharger
Remove the oil filler cap.
Fig. 8: Removing Oil Filler Cap
Courtesy of JAGUAR CARS, INC.
Remove the engine cover.
Fig. 9: Removing Engine Cover
Vehicles with supercharger
Fig. 10: Removing Engine Cover
All vehicles
Remove the cowl vent screen. FRONT END BODY PANELS (2003.5-09)
NOTE:Vehicles with supercharger shown, vehicles with 3.5L or 4.2L engine without supercharger similar.
NOTE:Left-hand shown, right-hand similar.
Fig. 11: Removing Engine Compartment Supports
Remove the engine compartment supports.
Loosen the throttle body intake pipe retaining clip.
Fig. 12: Loosening Throttle Body Intake Pipe Retaining Clip
Detach the air filter outlet pipe
Fig. 13: Detaching Air Filter Outlet Pipe
Remove the throttle body intake pipe.
Detach the throttle body intake pipe.
Fig. 14: Removing Throttle Body Intake Pipe
All vehicles
NOTE:Right-hand drive vehicles shown, left-hand drive vehicles similar.
Fig. 15: Removing Engine Compartment Outer Panel Insulation
Remove the engine compartment outer panel insulation.
Remove the engine compartment outer panel.
Fig. 16: Removing Engine Compartment Outer Panel
Left-hand drive vehicles
Remove the engine compartment outer access panel.
Fig. 17: Removing Engine Compartment Outer Access Panel
All vehicles
Remove the cabin air filter.
Detach the cabin air filter.
Fig. 18: Removing Cabin Air Filter
Remove the cabin filter housing.
Remove the cabin filter housing retaining nuts.
Fig. 19: Removing Cabin Filter Housing
Detach the engine compartment outer panel.
Remove the engine compartment outer panel retaining bolt.
Fig. 20: Detaching Engine Compartment Outer Panel
Detach the hood release cable.
Fig. 21: Removing Engine Compartment Outer Panel
Remove the engine compartment supports spacing plate.
Fig. 22: Removing Engine Compartment Supports Spacing Plate
Fig. 23: Detaching Engine Compartment Inner Panel Insulation
Detach the engine compartment inner panel insulation.
Fig. 24: Removing Left-Hand Engine Compartment Inner Panel
Remove the left-hand engine compartment inner panel.
NOTE:Left-hand drive vehicles shown, right-hand drive vehicles similar.
Fig. 25: Removing Right-Hand Engine Compartment Inner Panel
Remove the right-hand engine compartment inner panel.
Detach the camshaft position (CMP) sensor electrical connector.
Fig. 26: Detaching Camshaft Position (CMP) Sensor Electrical Connector
Disconnect the CMP sensor electrical connector.
Fig. 27: Disconnecting CMP Sensor Electrical Connector
Remove the CMP sensor.
Fig. 28: Removing CMP Sensor
Installation
To install, reverse the removal procedure,
Tighten to 7 N.m.
Fig. 29: Tightening Bolts With Torque Specification
Fig. 30: Tightening Bolts With Torque Specification
Tighten to 25 N.m.
Camshaft Position (CMP) Sensor RH (18.31.11)
Removal
Fig. 31: Removing Oil Filler Cap
Fig. 32: Removing Engine Cover
Fig. 33: Removing Engine Cover
All vehicles
Fig. 34: Removing Engine Compartment Supports
Fig. 35: Loosening Throttle Body Intake Pipe Retaining Clip
Fig. 36: Detaching Air Filter Outlet Pipe
Fig. 37: Removing Throttle Body Intake Pipe
All vehicles
Fig. 38: Removing Engine Compartment Outer Panel Insulation
Fig. 39: Removing Engine Compartment Outer Panel
Fig. 40: Removing Engine Compartment Outer Access Panel
All vehicles
Fig. 41: Removing Cabin Air Filter
Fig. 42: Removing Cabin Filter Housing
Fig. 43: Detaching Engine Compartment Outer Panel
Fig. 44: Detaching Hood Release Cable
Remove the engine compartment support spacing plate.
Fig. 45: Removing Engine Compartment Support Spacing Plate
Fig. 46: Detaching Engine Compartment Inner Panel Insulation
Fig. 47: Removing Left-Hand Engine Compartment Inner Panel
Fig. 48: Removing Right-Hand Engine Compartment Inner Panel
Fig. 49: Detaching Camshaft Position (CMP) Sensor Electrical Connector
Fig. 50: Disconnecting CMP Sensor Electrical Connector
Fig. 51: Removing CMP Sensor
Installation
Tighten to 7 N.m.
Fig. 52: Tightening Bolts With Torque Specification
Fig. 53: Tightening Bolts With Torque Specification
Tighten to 25 N.m.
May 9, 2010 at 3:45 AM
