2004 Jaguar X-Type Headlight bulbs
2004 JAGUAR X-TYPE
OYSTER96
Electrical problem
2004 Jaguar X-Type 6 cyl All Wheel Drive Automatic
It call for a HI bulb. Is there a bulb? Also, how do you replace the bulb on both sides. Thank you.
Feb 18, 2010 at 2:41 PM
DAVE H
  • 13,384 POSTS
Headlamp Bulb - Vehicles With: High Intensity Discharge Headlamps
Removal
Remove the headlamp assembly. For additional information, refer to HEADLAMP ASSEMBLY (Section)
Remove the bulb cover.
Detach the bulb cover retaining clips.
NOTE:The igniter assembly electrical connector will automatically release as the igniter assembly is rotated.
Remove the igniter assembly.
Detach the igniter assembly.
Remove the headlamp bulb retaining ring.
Remove the headlamp bulb.
Installation
To install, reverse the removal procedure.
Feb 24, 2010 at 6:51 PM
