2002 Jaguar X-Type wing mirror
2002 JAGUAR X-TYPE
140,000 MILES • 6 CYL • 4WD • MANUAL
WOODHATCH
My offside wing mirror is loose and needs tightening. I see no external screw fixings so assume either the black trim or the blue body trim needs popping (see pic). But which one and with what? I don't want to try popping the wrong one with a metal screwdriver in case I cause damage.
Anyone got some advice?
[img:44e11cfc2b]http://www.2carpros.com/forum/automotive_pictures/407358_wingmirror_3.jpg[/img:44e11cfc2b]
Sep 10, 2009 at 5:49 AM
DAVE H
  • 13,384 POSTS
Exterior Mirror
Removal
Remove the front door trim panel. For additional information, refer to FRONT DOOR TRIM PANEL .
Remove the window surround trim panel.
Fig. 4: Removing Window Surround Trim Panel
Courtesy of JAGUAR CARS, INC.
Disconnect the exterior mirror electrical connector.
Fig. 5: Disconnecting Exterior Mirror Electrical Connector
NOTE:Support the exterior mirror while removing the exterior mirror retaining nut.
Fig. 6: Detaching Exterior Mirror
Detach the exterior mirror.
Remove the exterior mirror.
Detach the grommet.
Fig. 7: Detaching Grommet
Installation
To install, reverse the removal procedure.
Tighten to 12 Nm.
Fig. 8: Installing Exterior Mirror
Exterior Mirror Control Switch
Removal
Remove the exterior mirror control switch.
Fig. 9: Removing Exterior Mirror Control Switch
Installation
Exterior Mirror
Cover Removal
Remove the exterior mirror glass. For additional information, refer to EXTERIOR MIRROR GLASS
Apply light pressure to the inner edge of the exterior mirror cover.
Fig. 10: Applying Light Pressure To Inner Edge Of Exterior Mirror Cover
Detach the outer edge of the exterior mirror cover.
Fig. 11: Detaching Outer Edge Of Exterior Mirror Cover
Remove the exterior mirror cover.
Fig. 12: Removing Exterior Mirror Cover
Installation
Exterior Mirror Glass
Removal
Apply light pressure to the mirror glass.
Fig. 13: Applying Light Pressure To Mirror Glass
Detach the mirror glass.
Apply light pressure to the inner edge of the mirror glass.
Fig. 14: Detaching Mirror Glass
Detach the exterior mirror glass.
Reposition the mirror glass motor.
Fig. 15: Detaching Exterior Mirror Glass
Disconnect the mirror glass heater electrical connectors.
Fig. 16: Disconnecting Mirror Glass Heater Electrical Connectors
Installation
Nov 30, 2009 at 7:25 PM
