Unfortunately, I can't provide you with any illustrations. The service that I get my repair data from prohibits me from sharing their illustrations with anyone.
But there may be another technician on this forum that has access to information that I don't.
As for your tranny fluid change:
Your transmission is located at the back of your engine. (It's actually bolted directly to the back of the engine)
If you get under the vehicle, you'll see the bottom of the engine, and right behind the engine, you'll see the bottom of the transmission.
You're transmission's drain plug is located at the very back of the bottom. The fill plug is located at the side. They look similar. (Round metal plugs with a hex-key opening in the middle)
You fill the tranny through the fill plug by squeezing the bottle into the opening. Fill the level to just under the hole.
Mar 18, 2010 at 11:20 PM
