2002 Jaguar X-Type air conditioning & heater air vents
2002 JAGUAR X-TYPE
50,000 MILES • 6 CYL • AWD • AUTOMATIC
GEEKAY3
I have a climate control unit and the air conditioning & heat only come thru the defrost area. The buttons that indicate mid-level of floor vents do not work. Is this a problem with the climate control unit or is it one of the blend door actuators? (there are 4).
Jul 18, 2010 at 2:50 PM
DAVE H
  • 13,384 POSTS
I would be checking the Defrost Vent/Register Blend Door Actuator
https://www.2carpros.com/forum/automotive_pictures/266999_jag_116.jpg
Removal Remove the lower vent. Detach the bulb holder. Remove the lower vent. Disconnect the defrost vent/register blend door actuator electrical connector. .Remove the defrost vent/register blend door actuator. Remove the retaining screws. Installation To install, reverse the removal procedure.
Jul 18, 2010 at 4:18 PM
