2001 Jaguar Vanden Plas fuel tank connections
2001 JAGUAR VANDEN PLAS
VDPJAGOWNER
2001 Jaguar Vanden Plas V8 Two Wheel Drive Automatic
I had to pull the fuel tank out of my 2001 Jaguar VDP. When I pulled it to the rear of the car the fuel supply line pulled out of the fuel tank. My question is how do i lock the line back into the port that it came out of. I can not see the type of connection that they used because I didn't pull it all the way out when I replaced the fuel pump/
Mar 6, 2010 at 7:32 PM
DAVE H
  • 13,384 POSTS
there should be a spring clip fitting ! .. you will need to pull the tank out more to locate the fitting
Mar 17, 2010 at 3:35 AM
