I am getting cold air from the center part of the vents on the dash board, warm air from the sides of the same vent , and warm air on the bottom ( feet) vents! this with the temperature set at the lowest, if I put the temperature up a few degrees I get warm air everywhere, and it gets hot inside.
I had the frion checked and it is OK
What could be a valve stuck? some tem. probe defective ?
The problem started suddenly, at one point went back to funcioning properly, that the problem started again.
Any suggestions?
Thank you.
Any suggestions?
Thank you.
Feb 18, 2009 at 7:10 PM
