2000 Jaguar Vanden Plas how do iset the timing
2000 JAGUAR VANDEN PLAS
KPADEH G. BAYSAH
Engine Mechanical problem
2000 Jaguar Vanden Plas V8 Two Wheel Drive Automatic
i replace my timing chain and i forgot the timing pls help the timing seting
May 4, 2009 at 11:25 AM
DAVE H
  • 13,384 POSTS
PRIMARY TIMING CHAINS (NON-SUPERCHARGED)
NOTE:The 4.0L V8 has no engine timing alignment marks on the crankshaft or camshafts. Engine timing is achieved by installing the Crankshaft Setting Peg (303-531) and Camshaft Locking Tool (303-530). With the crankshaft setting peg in position, ensure the timing flat on each camshaft is in the uppermost position before installing camshaft locking tool. Variable camshaft timing unit may also be referred to as Variable Valve Timing (VVT) unit.
NOTE:Special Tools Required: Crankshaft Setting Peg (303-531), Camshaft Locking Tool (303-530), Chain Tensioning Tool (303-532), Primary Chain Wedge (303-533) and Variable Camshaft Timing Oil Control Unit Setting Tool (303-654). See Fig. 232-Fig. 236 .
NOTE:"A" bank refers to the right/passenger side of the vehicle and "B" bank refers to left/driver side of the vehicle.
Nov 27, 2009 at 6:33 AM
