1998 Jaguar Vanden Plas engine cranks but will not start
1998 JAGUAR VANDEN PLAS
74,300 MILES • V8 • 2WD • AUTOMATIC
BRAD50020
engine crank but will not start is this an electrical problem, how do I correct this issue?
May 10, 2010 at 9:59 PM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 10, 2010 at 10:18 PM
